IT is but its better if you do it like this
Quest 2 - Wireless AP - PC
Ok, looks like I need to get a wifi dongle/card for my desktop then, cheers.
Is it worth creating a separate network or VLAN just for my Quest 2 and only have 5Ghz available?
It must connect at 5GHz (I get ~867Mbps) on my main WiFi network which has >10 devices on, but have seen internet rumours about a supposed benefit segregating it off.
Thank you, will look into it at the weekend. On a side note, is MAC filtering worth it? I have a separate guest network but just a bog standard long ass password for my main WiFi network.Yeah, it seems to work better for me with only the quest 2 on the 5GHz band. The way I did it was turn on mac address filtering and only allow the Quest 2 to connect. That way I don't even have to use a password on the 5Ghz network.
Apologies, I misunderstood and thus asked the wrong question. Thought you meant you also used MAC filtering in other parts of your home network (was curious if it was worth using in more normal use cases). I can definitely see the benefit in this case as my WiFi password is horrendously longIt depends on yourself. I just think it's the easiest way. Turn on Mac Filtering, Put the Quest 2 mac address in, disable password. I don't think it's a requirement, though some people claim that the latency is lower when you use Mac filtering and turn off the password. I haven't any data to say that's true or not.
For me it was ease of use, as I had to reset my Quest 2 and didn't have to worry about putting the password in again.
.Thank you, will look into it at the weekend. On a side note, is MAC filtering worth it? I have a separate guest network but just a bog standard long ass password for my main WiFi network.
Erm, nope you shouldn't need one. Or maybe I didn't understand your previous post. You have a wireless access point, a switch and Router for the internet? IF you have all those you don't need a dongle or a wifi card.
You connect your computer to the Wireless access point, then connect your Router and Access point to the switch. If your Wireless Access point only has one network port, then you connect your computer to the switch instead.
Is your Wireless Access point 5Ghz?
I meant that my PC is connected via ethernet to a switch (same room) which is connected to my router via another switch in a different part of the house. This room doesn't get wifi signal so I also have a wireless access point plugged into the switch for phones/tablets. If I can use it in that configuration then great, otherwise I can either connect my PC directly to the AP or get a dongle/card to connect it wirelessly?
Sorry, got busy at work. How about you just tell me the make and model of your Wireless Access point? I can give better advice then.
The one I have at the moment is cheap junk, not 5GHz. It'll be getting replaced with something much better for this so if you've got a recommendation that would be great
 and the creator of Virtual Desktop recommends connecting your Quest to your PC using a router.
• Improved controller prediction smoothness and accuracy
• Fixed issue with black bars in some games
• Fixed issue with haptics not working in many Oculus games
• Fixed game compatibility with: Tales of Glory
GPU/CPU: 1080ti, 4790k
Router: T-P Link AX1500 (AX10) (5GHz)
Network Setup: Router on desk 1Gbps ethernet to PC and Quest within 5 meters
VD Reported Speed: 1200 Mbps
VD Streaming Settings: Quality - High, FPS - 90, Bitrate - 80, Sliced Encoding - On, Video Buffer Off, Auto Bitrate Off
VD Codec: H264
Other Settings: router set to AP mode, 2.4ghz off, 80mhz, manual channel
Desktop Latency: ~20ms
Game Latency:
-Beat Saber: 25-40ms
starts off great until I get into gameplay, I tried lowering in-game settings.. all my individual latencies seem ok but it just has trouble keeping 90fps and I see microstutter if I watch the blocks coming at me closely. a few bigger hitches.
I think my wifi signal is just too busy in this apartment building, all the ranges seem quite busy. pretty acceptable for slower paced games but not perfect.
I have a 5900x on backorder for almost 6 weeks now, wondering if that will help at all..
I'd say try lowering video quality to medium as a 1080 is going to have a bit of a workout with it set to high. Also beatsaber isn't a game I'd want to play over wifi streaming as it needs zero latency.
I have a good setup and it works very well but I bought beatsaber for the quest as it is a much better experience on the native quest app, ymmv.
Will give that a shot, I just figured beat saber was a quick test which would show me problems instantly. I would like to use VD to play the 360 mode.. I haven't bought it (again) on quest because I have so many custom songs and mods on PC already.. I mostly play Synth Riders on quest directly tho. One issue I've noticed is when I'm in a game there isn't an easy way to quit out, normally you'd hit the oculus button and hit 'close' but now that brings you to the Quest 2 dash not the Rift dash.. you can hold down options button to get to the VD menu and hit quit but that closes everything back to quest as well.. am I missing something? I was using Oculus First Contact to test out the latency before and had to close everything to quit mid game..
p.s. I noticed there's a bunch of rtx 2070 owners who use High, are they actually better for VR performance finally? 1080ti should be somewhere around a 2070-2070super level of performance for pancake games.. with more vram.
Sorry I misread as a bog standard 1080.
When using VD the way I close is by going to the VD menu and lcsoing the VR game there, as that is where it luanched from and is the only way to launch games from PC in VD isn't it?
What are you wanting to quit to that you can't?
Getting to the rift dash would onyl be useful if using the link? I've not bothered with the link yet as the wifi is good enough.
Not much help, sorry
Hi all,
I got the Quest 2 for Christmas and as a big hater of cables I have bought the Honor 3 router so I could have an smooth wireless experience.
Unfortunately I get some shuttering while playing Alyx.
My set up is as follow:
My PC is a ryzen 3600x with a 3070.
Honor router connected by cable to the PC (gigabit) and 5ghz exclusively for oculus.
I have tried to play the game with oculus link and runs smooth as anything but VD is not behaving so nicely
Any suggestions? I have, tried with different codecs already, and lowering the bitrate to minimum on VD but no joy.
I had a very similar problem, I fixed this by clicking on the Half-Life program on the pc to make sure it was in front of other programs, if I'd VD or other programs at the front I would get stutter.
Strange issue but this fixed it.
Folks, I want to use my PC wifi onboard as a hot spot but the 5GHz is not allowing to be enabled, it says "The selected network band isnt available" Select a different band and try again.
Thsi is a WiFi 6 AX201 160MHz Wifi capability, presumably this could be capable of connecting at 1200Mbs?
I would be grateful for your insights.
