Incoming moaning...
I just did a complete fresh install of Windows 10 on one of my systems - first time I've done a complete fresh install in awhile...
What a ******* ball ache - so much to skip, defer or fill out with useless information/settings just to get past it so I can disable later, spent a good hour plus then disabling or uninstalling features, etc. only for half the time Windows 10 to randomly decide there was an incompatibility and try to reset settings because half an hour later or so it had decided to launch the installation/modification of something in the background like Skype, etc.
Got everything finally up and running with all drivers installed and then bam unresponsive start menu! and constant notification sound (seems Windows 10 doesn't like having a WiFi adapter disabled - probably have to disable some Wireless related service somewhere).
I mean seriously... absolute amateur **** show. I can't believe people defend this OS.
Oh and file explorer still looks like an aborted mess - for some reason I had kind of started to ignore it but doing a fresh install and going back and forth from the downloads folder to sort drivers, etc. had me constantly using it.
EDIT: Oh and now back to my main Windows 7 desktop after spending the last few hours messing about with that - so nice to not have to look at that hateful UI.
