I’ve played for 14 hours now and I’ve only seen any texture pop in once, when I was driving along beside the river and I could see one of the parallel elevated roads being rendered, but it really was quite far into the distance. Truly impressive.
Don't get me wrong id like better performance
I'm getting 60 FPS pretty solid with quite an aging setup other than the 3070FE with only 2 settings on ultra rather than psycho.You want an Ampere cardI'm getting 60 FPS pretty solid with quite an aging setup other than the 3070FE with only 2 settings on ultra rather than psycho.
What res you running?most stuff you won't notice without looking for it apart from the obvious fake traffic in the distance on highways outside of town.I’ve played for 14 hours now and I’ve only seen any texture pop in once, when I was driving along beside the river and I could see one of the parallel elevated roads being rendered, but it really was quite far into the distance. Truly impressive.
Why do people even have browsers open anyway when gaming, everything should be closed down.
If you're on an AMD CPU that's because the game isn't utilising logical cores. You can fix this by changing a tiny part of the executable in a hex editorNo I don't want Ampere, I'll buy a 6900xt before I buy an Ampere card and you know this.What res you running?
The other oddity I noticed is that none of my cpu cores ever seem to go over 50% utilisation almost like there isn't a main world thread like most games and my gpu sticks at 92%
Too quick to forget Witcher 3 launch if you think this is the caseWill be interesting to see the "Hero to Zero" style mini documentaries about CD project red that will come from this launch.
CDPR can fix it for me. Am on a Threadripper 1950xToo quick to forget Witcher 3 launch if you think this is the case
He's got to be a sad lonely little **** to be trolling this muchDon't feed the troll.
This isn’t the case at all according to the November 2020 Steam hardware and software survey. 44.11% of those surveyed are on 4 cores with the next highest being 26.94% using 6. As for RAM 16GB holds the highest percentage at 43.24% followed by 8GB with 29.47%.Dude, come on. We're in a time of 10 - 20 cores with most people on 24 - 32GB these days. This isn't 2004.
Did not know about tip 1. Tyvm.For everyone loving this game as I am, can we started sharing tips?
Tip 1 - If you go to back of your car to the boot you can store your items in your stash.
Tip 2 - If you hold the summon car button you can select any car from your garage.
