For everyone loving this game as I am, can we started sharing tips?
Tip 1 - If you go to back of your car to the boot you can store your items in your stash.
Tip 2 - If you hold the summon car button you can select any car from your garage.
Tip 3 - If you take all items with you, you end up walking really slow. It's because you quickly picked up everything and became slow because of weight, not because you are injured. It took me ~30 mins to realise this before I eventually worked it out how to drop things like loads of clothes
I've managed to fix my FPS! I found an obscure thread on reddit talking about the asus suite III software. I installed this months ago and deleted shortly after, apparently deleting isn't enough and only a format will do.
I'd used the hex editor, power management, config tweaks and saw maybe 5-10 fps more (coming from 50-60 fps). I also saw no change when changing resolutions from 1080p, 1440p or 4k. (same 60-70 fps). Now I've formatted (not even on the latest drivers) I am getting 150 on 1080p and 100-120 on 1440p.
So looks like it's solved! Hope this helps someone else. If you want to try a fresh format, you can partition C and give it ago that way. I'd been looking for hours for a fix!
Specs 3080 FE and a 5600x
Nice, what settings? Presuming not 100fps with RTX enabled
