Hi all,
Just put together a new PC
3700X (wraith prism stock cooler)
3060TI (gigabyte 2 fan)
This case https://www.xigmatek.com/product_detail.php?item=192
Currently 3 fans - 1 rear two at the front
NZXT temps here: https://imgur.com/a/86kPBdD
Once I open the acrylic side, the temps pretty quickly plunge from 90 to 75 and as low as 45 whilst gaming
With this, playing gears 5, my temps go quite high. I have seen reviews and under load, (with reviewers) they don't go this high. So a few questions
1) Are they too high in your opinion
2) Anything else I can do without buying a new case - happy to buy a case, it's just the faff of re-building everything in there that puts me off!
3) I have space for 3 more fans, but 2 of them would sit on the PSU cover, so I don't see where the air could go and 1 I lost with my new builds as I cant seem to fit it in anymore alongside the new CPU cables!
4) can I assume that because the temps plunge when I take the side cover off, it's the case that has bad airflow?
Thank you!
Thank you!
