Yes hahaLove the photos -- did the harribos come with the GPU?
Nothing. I think overclockers now need to step in and reallocate people on this line and start offering other cards out. At least there is some movement on other cards but the zotac is literally a wasteland.
Is there a way to find out my pos in queue? I haven't received any emails from OC since initial recepit.
A nice 8am delivery today. Last day at work for two weeks also today. So its a merry Christmas for me.
Thanks for the added haribo tangfastics that was also in the box.
Have a merry Christmas ocuk
And good luck for all those who are waiting.
Loads of 3080s coming into stock in the UK today, prices are still inflated though.
Yay My ban has lifted. Happy days! How can i go about pre ordering me a strix 3080 OC or FTW3 Ultra ?
Lucky you I'm Num 64No zotac non OC trinitys though
been number 2 for weeks...the torture ha.
Just had two in basket elsewhere and was told I had 15 mins to check out. Spent a couple of minutes deciding which I wanted and then it cleared my basket waaay before 15 mins![]()
you need to be quick, thats the place right now that has them
they have upped their anti bots software and causing some issues I noticed too, if you get the basket has something but is empty.. add something then remove it or it may say you have too many and can buy 1 only error.You shouldn't have to be when it tells you its reserved once in basket!
just add the one you want back and wait for it to land in the basket again, many dont buy in end .. so try again, thats how i got mine they were always in other peoples baskets, just have one window open for the site , dont try adding more than one in different windows or it will error and never add to your basket.Looking like the moments gone, lesson learned. I'm not that fussed tbh only really want one for Cyberpunk and by the sounds of it giving them a few months to fix that would before playing would be beneficial anyway.
