Finally got an order in for 3090FE.
Not here yet obviously but hopefully this side of Christmas.![]()
Its all that POWER.
Tempted to try the quiet BIOS
I know right lol, even just 105% PL that I've got now results in 410w power draw at full load - I'm already starting to regret not getting the kingpin - a 360mm AIo would cut at 20-30c off these temps
What kind of core clock frequency does it settle at under gaming?
I noticed if I left my Gigabyte Vision to its own devices it tends to fall down to 1890mhz or so, but now with a bit of tweaking it sits at 1935mhz solid at 875mV. After a long RDR2 session it hits 70C on maxed out settings 3400x1440p. In Horizon Zero Dawn maxed out, its more like 60-66C. 105% max power limit.
1950mhz. I haven't tried any voltage mods.
With 123% PL it sits between 2000 and 2050 but gets too hot
So I have noticed that RT games generate a lot more heat. My FE at stock stabilises at around 62% fan speed in timespy stress test but whilst playing metro exodus the fans are around 70-75%, which sounds like a get engine. Increasing power limit makes the fans go all the way to 100% during intense ray tracing gaming as the default bios seems to target 69-70c temperate.
Seems to be a major oversight by the reviewers as none of them mentioned that the card becomes a jet engine when playing RT games. I was under the impression that the card is quite but it is definitely not. Anything above 50% fans speed is noticeable and 65%+ is unbearably loud.
The Asus Strix runs quite toasty
room temp: 26c
Humidity: 80%
Strix 3090 performance bios (stock): temp sit at 70c with 70% fan speed.
Strix 3090 overclocked (123% PL): temp 80c with 80% fan speed
For 24/7 use I've settled on 105% PL, +50mhz on the core and +200mhz on the memory (3d mark score is 3% lower than 123% PL): I've going to use custom curve to make sure the fan doesn't go over 65% and then see where the temps land (under 80c and I'll be ok)
So I have noticed that RT games generate a lot more heat..
Seems to be a major oversight by the reviewers as none of them mentioned that the card becomes a jet engine when playing RT games. I was under the impression that the card is quiet but it is definitely not. Anything above 50% fans speed is noticeable and 65%+ is unbearably loud.
If you change your editorial direction we might let you buy one of our cards...
