- 7 Sep 2020
- Gods Country
You obviously missed the part where the OP stated water was be driven in through the brickwork in bad weather. Ventilation alone won’t sort that out and warm air condensing on cold tools will cause them to go damp and rusty.How have we gone from sorting out some condensation in a garage to making it a full blown heated room?
It’s a build up of moisture over time which has become trapped due to inadequate ventilation. Condensation is just an imbalance between moisture and ventilation. It’s normal for a bit of moisture to get in as long as it can get out again.
why not spend that little bit more money to ensure it doesn’t happen for any reason and keep the expensive equipment dry and rust free.
