- 7 Sep 2020
- Gods Country
Defo not 1.5 to 2k that’s for sure.......Not bad at all.
I’m glad I don’t shop were you guys domy double garage is 6.2x6 and all materials to insulate (50mm insulation, osb, batons, fixings etc) were just under £1k to give you some perspective (inc ceiling)
Your prices were extremely good, I can't even get foiled insulation at that price trade round here.
Good question. The humidistat was set to target 50% so I’m not yet sure. The obvious reasons would be either the dehumidifier is operating at its maximum capability or the influx of the external air mass through leaks is levelling it out. Or both. Or maybe the contents of the garage (cardboard boxes etc.) are still drying out? Having spoken to the manufacturer before buying they suggested the unit should be more than capable of bringing the RH lower so I’m leaning towards the air leaks. I’ll plug it up and see if that has any effect.Why does it suddenly stop reducing the RH? Does it switch off? Is the garage well sealed?
45-50% is the target to apparently stop all corrosion. Below 60% seems essential.
It looks like a neat setup.
