- 2 Dec 2020
- Boarding a Rocket Ship
Th
Thats a great post, thanks!!
My scenario
Im on mission 3 or 4 of Su27 flaming cliffs campaign. I take off to intercept 2 f16s. I go BVR and select longest range missile the 27ER radar guided.
They are jamming me with ecm so it ends up in shorter range which by that time they launch a 120 i think. What should i be doing at this point? Looking at missile labels to see how close or use RWR? Changing course and evade on the defensive like you said about letting missile run out of steam....
Thing is im always on the defensive, how am i to get a shot off as they keep launching missiles with which i managed to avoid 3 missiles but then get hit.
Tried same mission 7 times and still same, am i supposed to take all they got and dodge all missiles before i can fire?
I always drop chaff/flare auto dispense, i know chaff are radar guided and flare are for IR guided.
I used to play all the old sims like janes and microprose gunship, f15, f117a.
Not a noob but a noob at DCS bigtime im struggling abit.
Anybody on here got any vids i can look at?
Anybody with any help please chime in, i love this game but i just need some pointing in right direction please
It's worth going to have a good read around things if you're dropping flares.
The basics are:
- The 120 is a Fox 3, radar guided missile. This means that the aircraft radar normally provides guidance to the missile until 10 seconds before the missile is due to hit the target, at which point the missile goes "pitbull" and turns on it's own radar to track the target
- As the missile is radar guided, flares will have no effect. You should/could be using chaff. Don't drop 1 though. A stick of 10 in a sequence is typically more effective
- The 120, like any A2A missile is fired using it's internal rocket motor. Be aware that they only burn for a few seconds, which accelerates the missile to mach 3 for the 120. Post that burn, the missile is "coasting", and therefore decelerating. You can burn off the energy of the missile (i.e. it's speed) by making the missile make changes to it's course
- Be aware of the range of missiles. The 120 is "approx" 20 miles. However, if you're chasing a target, it's far less and if the target is coming directly towards you, clearly that increases. If firing a missile, being high and fast helps. The other way around, if you're at low level as the target, air density increases, which adds drag and slows missiles even more
- A2A missiles typically try to plot an "intercept" course for their target. As such, they'll be trying to fly to a point in front of your aircraft
- Good defensive tactics includes "notching" (worth looking that up). In rough terms, if you're flying towards the enemy, turn left, meaning that the missile will turn in that direction, then make a hard 180 degree turn. Chances are that the missile won't have the energy to come after you. Notching doesn't need to be just in the horizontal plane. IMO, it's also good to use the vertical plane aswell.
- Radar guided missiles are dependant upon the radar being able to see you. If you're low level, you can use cover (hills) to hide behind, which will break a radar lock
- The F14, F15, F16 and F18 all have bother Range Whilst Scan and Track Whilst Scan mode. In Range Whilst Scan, when a missile is launched, your radar warning receiver will let you know. However, if a player is feeling more sneaky (and good ones will), they'll use TWS. For that mode, you do NOT get a warning when the missile is launched. Instead, you'll get an RWR warning when the missile goes "pitbull", meaning that you've got just 10 seconds to evade. Unsurprisingly, it's a LOT more dangerous.
Once you think that you understand the above, go set yourself up a mission using the editor such that you can keep practising being shot at evading missiles
My scenario
) If you have no need for the split throttle, the CH + MSFFB is all you ever need (want is another matter).
