- 1 Jan 2003
- Derbyshire
It's only a bit of fun
Variation in windows 10 builds, some if most are not up to date or on the latest build. Scoreboard not indicative. Not a level playing field.
I find this is difficult bench as there are so many variants. Are we to use SMAA4x or other? In above SMAA4x is used, initial post does not include display settings[/
It's once you change Screen space contact shadows to high its changes preset from highest to custom.
I guess its down to trust.
Thanks. What a tard, ignore meIt does say in the OP, Listed under settings in a spoiler
DX12
1080P
8700k 5GHZ
RX 6900 XT 2725core2100mem
21.1.1
1440p
1080p![]()
Yeh, @pete910 pointed out - just me being blind. Thanks bothYes it does.![]()
Sure. Happy to oblige. I can run 1920x1080 but I can't select 'normal' 1440 or 2160. I'll run and post results for 1080p and 3440x1440...@heartburnron tbh we really lack 1080p and 1440p data for the new cards. I would appreciate at least a 1440p run if you have the time.
I will run some 1080P and 1440P runs when i have the game downloaded. From memory i think i got 145FPS or thereabouts at 1080P using the settings in the OP.@heartburnron tbh we really lack 1080p and 1440p data for the new cards. I would appreciate at least a 1440p run if you have the time.
