Except you have a chance of buying a 3090 before next Xmas.This would pretty much be identical to a 3090 in almost every situation surely, making the 3090 essentially redundant. The difference in bandwidth would be unlikely to translate in to huge performance differences...
cyberpunk just about uses 10gb of vram. based on that new games are going to top 10gb..that 20gb is going to be needed.
Except you have a chance of buying a 3090 before next Xmas.![]()
By the time its needed you will need to be turning down setting anyway to hit 60fps.cyberpunk just about uses 10gb of vram. based on that new games are going to top 10gb..that 20gb is going to be needed.
I have seen 16gb vram usage when using vr at native resolution on a quest 2. So for vr at least 10gb is no where near enough.
Half life Alex using steam and fpsvr to monitor FPS and ram usage. It said 16gb/24gb so I assume actual usage. Native Res on quest 2 is higher than 4k because of the distortion adjust ment.What hardware/software was that using? Was this allocated or actual used VRAM?
Can someone tell me what the point of a 192bit 3060 is with 12gb ram?![]()
MSI afterburner says otherwise. also i never said full 20gigs is needed. i said 10gb is not enough.. and its not enough.Please learn the difference between VRAM allocation vs usage. 20GB VRAM won't be "needed" for at least another 5+ years.
