Artic Silver 5 - strong stuff
7 Jul 2008
Newcastle upon Tyne
bought some Artic Silver a couple of weeks ago for my Ryzen 5800 and AIO.
today I decided to rebuild the pc into a new case. Removed the screws holding the AIO pump and it would not come off. used a bit more force and it came off taking the cpu with it
flippin ek, strong stuff and something I have never encountered before. CPU is fine btw
14 Oct 2007
newcastle
If you run a stress test to get the chip nice and warm before taking the cooler off, it comes off quite nicely
1 Nov 2002
Sussex
Pretty common especially with AMD chips, often will pull them straight out of the CPU bracket. Best thing is to get them a bit warm, and if possible twist the cooler off slightly. So many people have bent pins because they pulled it straight out or off and it’s flown across the room!
