Hi,
I'm looking to overclock my i7 7820x and was hoping for some advice.
This is my first time overclocking a CPU, the most I've done in terms of overclocking is my GPU with Afterburner. And undoing an unstable overclock my motherboard had as standard when I bought it, that's about it.
My motherboard's the Asus TUF X299 Mark1 and I'm using Corsair Hydro Series H115i PRO for cooling.
For the overclock I'm using the TUF AI suite 3 which is a bit overwhelming with all the settings, I'm aware the majority of the setting don't need touching I just don't know what's what and would appreciate some advice.
I'm just looking for a mild to moderate overclock, nothing too extreme. Around 4.4 to 4.6ghz on all cores is about what I'm aiming for.
I'll leave a couple of pictures below of the AI suite I've found on the net, the top one is basically like for like but with 6 cores instead of 8, the bottom pic is the only one I could find of the setting, but it's not quite like for like with it being a different CPU in the pic, mine has 9 settings either side and this picture only has 6 either side.
If I can find a way to post my own pictures I will or I can just list the settings out if it helps, just ask.
Any info will be greatly appreciated, thanks.
