Yup the Velcro cables ties aren't necessary but it may makes things neater and you can use other stuff built into the case to help organise. Use whatever makes sense to you is my advice.
Depends on the case and cable length you have to work with, if tying things down helps keep things tidier then it can be worth it. If the case has good cable routing and things are tidy enough without, then there's no pressure to do it.
I tend to favour velcro straps where possible, don't have to faff about snipping cable ties off anytime something needs rerouting, but it's not really the end of the world if cable ties are the only option.
I use lots of cable ties. Using side cutters they’re really easy to remove when you need to move things. Velcro certainly has it’s place but you can’t bundle wires together quite as tightly with it.
