Don
- 20 Oct 2002
- Oxfordshire / Bucks
ignore
Are there not any differences between superhot for pc and it for quest like graphical downgrades? I bought Onward for quest, there are distinct graphical differences. Then I soon learnt about virtual desktop and wireless hookup of pcvr games and quest so I refunded my quest onward and bought it on pc to play it wireless in full graphical glory.
Ah right so quest version is better if anything, buy the quest version then. Plus there's no faffing about with your pc so you can stream it.with the Quest 2 updates to make it look better and introduce 90Hz, there's not noticeably any difference from what i can tell my googling
to me, its not worth getting a game like that on the PC if you have a quest 2
Pistol Whip
In Death Unchained
This is not something I have tested as I do not use wireless or have tried that game. Could it be worth while if you have a really high end GPU to have it on the PC over Quest as you can run higher settings like higher levels of FSAA. Not sure how that translates over wireless as I personally prefer Elite style games with a USB cable so never tried it.with the Quest 2 updates to make it look better and introduce 90Hz, there's not noticeably any difference from what i can tell my googling
pistol whip is great fun !
felt weird at first, moving forward when i wasn't, i thought i was in a shopping mall escalator
nearly fell over
im knacked after 3 maps and duels
So managed to grab the 64gb version from Amazon.... which cable do I need for the Oculus Link?
Cheers bud, what do you mean VRing away from computer? I thought you have to be close to your computer using the cable?
Any shorter alternatives?
Also are you using the usb c port on the front or back of your rig?
. Or use Virtual Desktop, which effectively streams the game from your PC over your WiFi (or of course just play standalone games on the headset).Cheers bud, what do you mean VRing away from computer? I thought you have to be close to your computer using the cable?
I have my computer in the living room which is a long rectangle. It’s a bit too narrow where the computer is and where the TV is so the 20 ft cable should take me down the front end away from both.
Of course if I am happy with Virtual Desktop and not needing a cable, I shall not bother with one.
I will be using the USB On the back of the computer as my mobo has dedicated VR USB sockets.
bigmike what benchmark is this you are using?
