The Ampere RTX 3080 Owners Thread
Just got my 3080 FE for the first build. Installed everything but when it's gaming full screen, the monitor loses signal. Anyone know what that might be? In windowed mode, there isn't an issue.
Also, is it normal for FE to hit 75c?
Have tried, full windows installation, full win installation with no net and manual driver installs. Can't get my head around it. Getting a Displayport cable delivered today and I'm hoping that solves the issue.
Here is mine from yesterdays drop. My custom 12 pin cable came today too.
Looks great, Is that an official cable connected to the GPU?
Thanks, no its a custom one I got off the guy on Etsy.
Have you checked that your refresh rate is set correctly in Nvidia Control Panel ? Could be your displayport cable.
75c in what benchmarking or games ? Benchmarking would say its fine, games maybe not so (for me) I like to keep it under 70c. With gsync off and it unleashed I get around 72c benchmarking same in games but if I limit it to my refresh rate of my monitor (75mhz) and enable GSync and vsync in Nvidia Control Panel (vsync off in games) then it averages 53-55c in games but it means I get minimum 75fps.
Seems normal. Mine will sit between 75c and 77c in intensive games with the default fan curve.
3080 FE I got a few days ago. Nice upgrade from a 3gb 1060!
Noticed a bit of plastic film on motherboard that I missed before! Will sort that sometime
May I recommend undervolting the card, I've just done it on my 3080FE, reduced power usage by 60W, reduced temps by 10c, clock speeds stabilised, and benchmarking figures either matched or slightly beat stock. I'm sat at a steady 1875Mhz at 0.875v, benchmarking I'm hitting 63c, playing Cyberpunk its 58-60c.
What model do you have? Try 1900Mhz @ 887mV.
I've undervolted the card a bit and it improved Time Spy score by 500 but that's about it, hasn't really lowered the temperature. I've installed my AIO fan at front to push air in which seems to have helped, the CPU at least. GPU is still getting to 70C in 3DMark .Not sure what else I can do about this GPU.
My figures are 1935Mhz / 862. I'm quite new to all this stuff so still learning everyday.
Have you done some tweaking to the fan curve? I'm trying to figure out a way to ramp up AIO fans if GPU hits a certain temp as they're the ones pushing air in.
Welcome and on TROH.:)
The Roll of Honour.
Date 28/12/2020, Make NVidia FE, nicRob, Link
Date 24/12/2020, Make EVGA FTW3 Ultra, Nghtmare, Link
Date 24/12/2020, Make NVidia FE, varkanoid, Link
Date 18/12/2020, Make Asus Strix, Ur round next, Link
Date 14/12/2020, Make Asus TUF, Vertigo1, Link
Date 13/12/2020, Make Gigabyte Vision, sprite-, Link
Date 12/12/2020, Make Gigabyte Aorus Master, Smiffy-UK, Link
Date 12/12/2020, Make Gigabyte Gaming, enigma27, Link
Date 10/12/2020, Make KFA2 SG, ns400r, Link
Date 09/12/2020, Make MSI Gaming X Trio, Naff8000, Link
Date 09/12/2020, Make MSI Suprim X, aelc89, Link
Date 08/12/2020, Make Gigabyte Gaming, Datamonkey, Link
Date 06/12/2020, Make NVidia FE, Sipha, Link
Date 03/12/2020, Make NVidia FE, Hasnain, Link
Date 03/12/2020, Make EVGA XC3 Ultra, Pohly, Link
Date 02/12/2020, Make Asus TUF, Space Monkey, Link
Date 01/12/2020, Make Zotac Amp Holoblack, Tweaker, Link
Date 01/12/2020, Make EVGA FTW3 Ultra, ryhoper1, Link
Date 28/11/2020, Make NVidia FE, Bozzler, Link
Date 28/11/2020, Make NVidia FE, Disco_P, Link
Date 26/11/2020, Make Palit GamingPro, Dnyeee, Link
Date 21/11/2020, Make EVGA FTW3 Ultra, zx|muppet, Link
Date 21/11/2020, Make Zotac Trinity, Devrij, Link
Date 20/11/2020, Make MSI Gaming X Trio, Silent_Scone, Link
Date 19/11/2020, Make Zotac Trinity, Woodsta888, Link
Date 19/11/2020, Make Gigabyte Aorus Master, vargojones, Link
Date 18/11/2020, Make Gigabyte Gaming, Digital X, Link
Date 14/11/2020, Make Zotac Trinity, Jae-So, Link
Date 14/11/2020, Make MSI Gaming X Trio, Bacalhau, Link
Date 09/11/2020, Make NVidia FE, b0rn2sk8, Link
Date 09/11/2020, Make MSI Gaming X Trio, Cecco, Link
Date 09/11/2020, Make MSI Gaming X Trio, Dave2150, Link
Date 09/11/2020, Make NVidia FE, Nick1881, Link
Date 08/11/2020, Make NVidia FE, TangoEchoAlpha, Link
Date 08/11/2020, Make NVidia FE, Katalyst, Link
Date 08/11/2020, Make MSI Gaming X Trio, Illuminist, Link
Date 08/11/2020, Make NVidia FE, z10m, Link
Date 08/11/2020, Make NVidia FE, sgavan, Link
Date 07/11/2020, Make MSI Gaming X Trio, arrow0309, Link
Date 07/11/2020, Make Gigabyte Gaming, robfosters, Link
Date 07/11/2020, Make NVidia FE, MrPils, Link
Date 07/11/2020, Make NVidia FE, TNA, Link
Date 06/11/2020, Make MSI Gaming X Trio, Lesh0430, Link
Date 06/11/2020, Make Asus TUF, Pij, Link
Date 06/11/2020, Make MSI Gaming X Trio, Cavallino, Link
Date 06/11/2020, Make NVidia FE, sunshinewelly, Link
Date 06/11/2020, Make MSI Gaming X Trio, Supertaff, Link
Date 05/11/2020, Make Asus TUF, Colonel_Klinck, Link
Date 04/11/2020, Make EVGA XC3, L-Digital82, Link
Date 03/11/2020, Make NVidia FE, DeenC, Link
Date 02/11/2020, Make NVidia FE, Thrillog, Link
Date 30/10/2020, Make NVidia FE, K4Y84, Link
Date 30/10/2020, Make NVidia FE, jrodga2k5, Link
Date 29/10/2020, Make Asus TUF, SeeNoWeevil, Link
Date 29/10/2020, Make NVidia FE, Rup, Link
Date 29/10/2020, Make NVidia FE, Joeyuk, Link
Date 29/10/2020, Make Zotac Trinity, will13, Link
Date 29/10/2020, Make Asus Strix, LegoManGB, Link
Date 27/10/2020, Make Asus Strix, 808wizard, Link
Date 27/10/2020, Make Asus TUF, ghutchison14078, Link
Date 26/10/2020, Make Palit GamingPro, Monty16v, Link
Date 26/10/2020, Make Palit GamingPro, Joeyuk, Link
Date 24/10/2020, Make Zotac Trinity, Spit, Link
Date 24/10/2020, Make Gigabyte Aorus, fx1, Link
Date 23/10/2020, Make Inno3D Twin X2, Toothy1911, Link
Date 22/10/2020, Make EVGA FTW3, DRZ, Link
Date 21/10/2020, Make NVidia FE, benjo, Link
Date 20/10/2020, Make NVidia FE, Mark011, Link
Date 20/10/2020, Make NVidia FE, haszek, Link
Date 18/10/2020, Make Gigabyte Gaming, BountyNunes, Link
Date 14/10/2020, Make EVGA FTW3 Ultra, Rom, Link
Date 12/10/2020, Make Zotac Trinity, Mr_Q_UKCS, Link
Date 10/10/2020, Make Asus TUF, XeNoNF50, Link
Date 10/10/2020, Make Asus TUF, Rup, Link
Date 09/10/2020, Make Zotac Trinity, TrM, Link
Date 09/10/2020, Make Palit GamingPro, Jlang, Link
Date 09/10/2020, Make Gigabyte Vision, Viirus, Link
Date 09/10/2020, Make MSI Ventus, Howling, Link
Date 08/10/2020, Make Gigabyte Vision, Deluxe1, Link
Date 08/10/2020, Make MSI Ventus, Setras, Link
Date 08/10/2020, Make MSI Gaming X Trio, Nemesis101, Link
Date 05/10/2020, Make NVidia FE, SurfXombie, Link
Date 05/10/2020, Make Palit GamingPro, jrodga2k5, Link
Date 05/10/2020, Make NVidia FE, AutoPilot, Link
Date 04/10/2020, Make Zotac Trinity, B1gdeano, Link
Date 04/10/2020, Make NVidia FE, degen, Link
Date 03/10/2020, Make NVidia FE, Katch, Link
Date 03/10/2020, Make Zotac Trinity, Samueltastic, Link
Date 01/10/2020, Make Asus TUF, Tafder, Link
Date 01/10/2020, Make Asus TUF, Sebastian Woolley, Link
Date 30/09/2020, Make NVidia FE, Dirk Diggler, Link
Date 29/09/2020, Make NVidia FE, Captain, Link
Date 29/09/2020, Make NVidia FE, LonelyDriver, Link
Date 29/09/2020, Make NVidia FE, IT Troll, Link
Date 26/09/2020, Make Asus TUF, Sparx, Link
Date 25/09/2020, Make Palit GamingPro, Kungfudave, Link
Date 25/09/2020, Make Asus TUF, FlyingFish, Link
Date 25/09/2020, Make NVidia FE, hideki, Link
Date 24/09/2020, Make MSI Gaming X Trio, jabski, Link
Date 24/09/2020, Make Palit GamingPro, Spikey, Link
Date 24/09/2020, Make MSI Ventus, XeNoNF50, Link
Date 24/09/2020, Make MSI Gaming X Trio, Gripen90, Link
Date 24/09/2020, Make Palit GamingPro, no_1_dave, Link
Date 24/09/2020, Make MSI Ventus, Joxeon, Link
Date 22/09/2020, Make Gigabyte Gaming, WiGgLr, Link
Date 22/09/2020, Make Palit GamingPro, Ace Modder, Link
Date 22/09/2020, Make Zotac Trinity, Ace Modder, Link
Date 22/09/2020, Make Zotac Trinity, Shockwave, Link
Date 21/09/2020, Make Zotac Trinity, InkZ, Link
Date 19/09/2020, Make Palit GamingPro, mingey, Link
Date 19/09/2020, Make Zotac Trinity, hyperseven, Link
Date 18/09/2020, Make MSI Gaming X Trio, Vogon, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 3080
If I had this 3080: 10G-P5-3897-KR
3080-ftw3-ultra-gaming-10gb
and this mobo
MSI b450-a pro max
What kind of support would I need for stability, to prevent sag?
I read someone bought a support because the card was heavy.
Can anyone link to the correct support to buy/order, please.
Got my PNY XLR8 3080 delivered today - replaced a 3060 Ti which I'd managed to get hold of earlier this month but will be sold on.
First point of business was to undervolt it, it's quite happily sitting at 806mv @ 1815mhz with temps of 65c and manageable audio levels - it will go under water soon though for even less noise :D
This is the performance the RTX 3080 owners can expect in F1 2018 at 2160p everything maxed out and SSRT shadows disabled, Ambient Occlusion is On, Anti-aliasing is set to TAA Checkerboard. Warm system.
