Damn, there goes my brief reign at the top with the No1 graphics score.5800x @4.8ghz + SAM
3800Mhz CL14
6900 XT 2650Mhz / 2150Mhz
https://www.3dmark.com/3dm/56103084?
Graphics Score
29 975
Physics Score
30 694
Combined Score
14 356
Overall : 27119
I don't know if I can stretch to your top spot gpu score of 30548.Damn, there goes my brief reign at the top with the No1 graphics score.![]()
I have every faith in you.I don't know if I can stretch to your top spot gpu score of 30548.
Out of respect I won't try, unless, someone else beats you and then I will take them down!I have every faith in you.
Lol, don't be daft! Put that AIB 6900 XT to use and beat it.Out of respect I won't try, unless, someone else beats you and then I will take them down!![]()
I have no idea what I'm doing yet, it seems to run faster when I turn things down.....Lol, don't be daft! Put that AIB 6900 XT to use and beat it.
Then i have an excuse to try again.![]()
Yeah, it needs tuning for sure. Check out MorePowerTool (MPT) and see what your default TDC and and Power Limits are.I have no idea what I'm doing yet, it seems to run faster when I turn things down.....
1080mv and 2600 mhz is faster than 1175 and 2700.. I need time to get used to it
I did try the mpt, but anything I changed, although worked in changing wattmatts settings, whenever I used them it would go into protect mode and put the clocks to 500mhzYeah, it needs tuning for sure. Check out MorePowerTool (MPT) and see what your default TDC and and Power Limits are.
The MBA 6900 XT has a Power Limit GPU of 255W and a TDC of 320A.
You may need MPT to extend your power limits to increase the score.
You only want to change the two things I mentioned or reduce voltage. Y can also reduce SOC voltage if you want to. Don’t do anything else and it will work.I did try the mpt, but anything I changed, although worked in changing wattmatts settings, whenever I used them it would go into protect mode and put the clocks to 500mhz
Do I need to restart after? And how does that work with the 15%slider? Do I just put it to full and it will apply to the new power limit?You only want to change the two things I mentioned or reduce voltage. Y can also reduce SOC voltage if you want to. Don’t do anything else and it will work.
Restart after. Keep PL at +15%, don't try changing it in MPT.Do I need to restart after? And how does that work with the 15%slider? Do I just put it to full and it will apply to the new power limit?
You can raise the Power Limit with MPT, for example like in this picture:It doesn't use the 3rd pin, that's the problem here. It has the exact same power as the nitro, the merc the reference
