I find DACs have quite a difference but I couldn't necessarily tell you what was "better" i.e. more accurate and less noise in anything that is moderately well designed or better. Anything based off legacy Burr-Brown designs tends to have what I call a "90s sound" for want of a better way to describe it - some call it warm but it isn't really - kind of slightly dark, smoothed (without necessarily losing detail) sound whereas for instance ESS based DACs tend to be slightly bright, brittle with a more clinical sound. A lot then depends on the circuitry around them - PCM and CS, etc. DACs with cheap and cheerful general purpose capacitors, etc. tend to sound dull even when they test well synthetically and have high SNR, etc. performance.
It isn't necessarily about the cost of them - for a lot of people it will be subjective based on what distortion sounds more agreeable to them.
 You are correct about diminishing returns and matching your system. I know I'm not that discerning and have recently purchased some Wharfdale EVO 4.2 speakers, which even with an old amp sound very good but once I can afford a decent AV receiver will sound better. I probably wouldn't get the value out of a system any higher end, besides which as you get higher end the sound of your room becomes more critical if you want to get the most out of your investment.
 I thought computing attracted some strange ideas but audio is on another level.
