Do I Need to Replace Battery Yet?
4 Jan 2021
Hi all, so i've been working from home for a few months now so not using the car as much, just the odd trip to the shop and back, nothing more than 15-20 minutes. I then went to start it over the weekend after a couple of days in the freezing cold and although it started first time, it chugged a little bit and took a good few seconds to finally start.
I checked voltage of the battery the next morning after sitting all day and it was 11.8 at the time and then when starting the car the cranking voltage dropped to around 9 then back up to over 14.
Is it just the cold thats not helping here and if I take it out for a proper driveevery now and then, can I still live with this battery for many more months to come if I keep an eye on it?
Its a stop start model so you are looking at £150+ for a new battery, something I could do without buying at the moment unless really needed.
OP
4 Jan 2021
How old is the battery? Anything in the car drawing a small amount of power?
Unsure of age to be honest, i've only had the car 2 years but its been in since then. Not sure of anything drawing power. I do have an aftermarket stereo in the car but not sure if anything on that could be drwaing power?
11.8v resting is flat get a charger for it. Loads of people need one these days. Solar is even easier
I do have a smart charger, will get it hooked up today. Hypothetically, what if it fully charges but then shows 11.8 again tomorrow? :)
30 Jul 2005
Midlands
If it fully charges then drops again then its battery replacement time.
Mines behaving like that. Full charge then after 1 week sitting in garage battery lost a load of volts and down to 12.2v. high self discharge probably sulfated up inside or other issues.
OP
4 Jan 2021
Ok, ill go whack her on charge now and leave it on and give it another test in the morning
30 Jul 2005
Midlands
Sooner the better get it on charge.
If you end up replacing battery you dont want same to happen again so if car not used much keep on charge or get solar panel. Since you said its i stop start battery it could be agm and those are not cheap and also those are supposed to be able to rapid recharge from alternator too. Very odd
OP
4 Jan 2021
Yeah its an AGM one. I was all ready to go out and buy one thinking batteries were only around £50 :D but then when I saw the price it got me thinking if I do really need to change. Ill see how it goes then for now, thanks
OP
4 Jan 2021
leave the battery disconnected otherwise you won't know if the voltage has dropped cos the battery is bad or because of voltage draw from something.
Ok, can I do this just by removing the neg terminal rather than taking it out? Will the car lose all its memory?
7 Nov 2004
East of England
To be honest, it doesn't sound like you need a new battery, it just sounds like the car needs a good run. By only running the car short distances over the last few months, each time with a stone cold start, you've almost certainly taken out more of the charge from the battery than you've put in. If the internals of the battery were on their way out, when you tried to start it in the freezing cold, it would have just failed. Those -3c morning when the car hasn't been started for a few days are the toughest time for batteries, and if they're a bit weak, they just won't start.
My advice - either use the car for a good journey or put it on charge (make sure you use the AGM setting on the smart charger too)
How old is the car?
OP
4 Jan 2021
How old is the car?
Car just turned 9 years old, cant say whether the battery has ever been changed as ive only had it just under 2 but has been fine in that time. I've got it hooked up to the smart charger on AGM mode now so ill let that complete and will also take it outf or a drive this week and monitor for the next week or so before buying anything. Hopefully wont be required.
Underboss
20 Oct 2002
Oxfordshire / Bucks
id be inclined to buy a new one for piece of mind
9 year car, if you havent got a receipt for a new battery, chances are its the same one still, how does the battery look? especially around the terminals ? very gunky ? look old ?
22 Jul 2006
What car is it?
Just paid £120 for a replacement suitable for stop start...I was going to get a charger but by the time I paid £50 for one I may as well buy a new battery as it was coming up to 6 year old anyway.
11 Oct 2005
Manchester, UK
I had the same issue. The car was only doing 2k miles per year prior to lockdown, I think it did less than 100 miles between March - December.
It had been struggling to start for a few weeks and then last Saturday, it was completely dead. I bought a trickle charger for £18 from screw fix and left it connecting for about 6 hours. I then took the car for a 40 mile drive to check everything was fine and then plugged it back into the trickle charger until it said charged.
It's been fine since and I plan to trickle charge it when I know its not going to be used for a while to keep the battery full. For £18, it's worth a go and it's handy to have one in anyway if you have a second car or you do very few miles.
OP
4 Jan 2021
Morning all, so I hooked up to the smart charger yesterday at 9.45ish and by 23:45 it had completed (14 hours). Checked voltage again this morning and it was down to 12v. Unfortunately I couldn't leave the negative terminal disconnected to test whether something in the car was draining the battery or not as I needed to use the car early this morning, so i'll charge it back up now and then leave the neg disconnected and then check voltage tonight.
So far though it seems that the battery probably isnt holding charge so a new one is probably needed.
p.s Car is a VW Passat, there is nothing clear stating a date on the battery, not by looking at the top anyway. Condition looks great, very clean.
