Folks how do I increase bit rate of virtual desktop up to 85? I can only set it to like 60?
That's the desktop bitrate you are changing. You want the video Bitrate in the streaming settings.
Hmm Im sure it was the video bitrate....
I saw some people talking about 85mbps?
So the VR bitrate is showing 61Mbps but the bar can be extended further... but no number is appearing after 61mbps....
not sure what to do here...
In the Virtual desktop streamer do you have the "automatically adjust bitrate" box checked?
I was just about to come on here and say Ive unticked the auto bitrate.
Thats done the trick, thank you so much.
There are so many options and I am not sure which ones to keep on and which ones off.
I now get 150Mbps for VR streaming, but is that overkill?
Playing Roborecall I did notice some stutter halfway through the game.... but I guess there are so many options to play with that could help with this? Any advice would be appreciated!
Glad you got it sortedand yeah, it's a minefield of settings.
150Mbs is overkill but it really depends on what GPU and wireless router you have. I would try it at 100 and see how it goes.
If you have a Nvidia GPU you should try "Spliced Encoding" on. In the Virtual desktop streamer, a lot of people are finding that H.264 is better than HEVC for the preferred codec.
There is option to enable performance overlay. It's a brilliant tool that lets you set the latency in game and where the problems are. And because you don't have to restart Virtual desktop after the most of the changes, you can quickly try out some settings and find what works best for you.
Here is the thread where people have posted their settings and some of their findings. Might help you out some.
Quest 2 Virtual Desktop Performance Thread | Overclockers UK Forums
Personally I find anything over 75mbps in the streaming section is absolutely fine. If you start going much over this you start to loose bandwidth for 90hz and start to get stuttering. You can go higher by lowering to 72hz and medium graphics so it’s a bit of personal preference.
I came across this video on YT:
Fairly logical... also I wonder about the ULL mode in NCPL which he mentioned.
The question for me is do we games like HL:Alyx wireless or via the link cable...
has anyone tried this and also the hp ?
Which strap is this one from Ali? I can see several
That is the one I got too (different seller but same headmount). I can't compare it too the official elite strap so can't say how it compares, but I can't imagine the elite strap is worth double the cost over it. I am delighted with mine.
