So tonight's job was to hang up an old shelf I got from Ikea a while ago and it fell down as I used small plasterboard wall pegs. I tried again tonight and used some larger plugs.
Something similar to this
Tested the shelf and it wasn't stable enough, can I salvage the existing holes I drilled and use something like anchor bolts or is it best I use new holes with the anchor bolts?
