- 15 Mar 2018
I (surprisingly) received my Nitro+ OC today. Have checked the end of it where the backplate is and mine looks to be pretty solid. No gap that I can see. Did yours come with a cover over the PCI connector? My box was sealed but I thought the PCI connector would have a plastic protector over it. The ports do have plastic covers on them.
Thanks for checking. If the card is sat on its back plate there is no gap but you you pick it up from around the shroud you feel the movement (which is when I noticed it when I was moving to have a good look at it). When mine is installed you can see the gap open as the weight of the fans and cowling pull on it. Do you have this gap when it's installed in your system?
I checked the screws in mine and they are tight so it might be that they crossed threaded both of mine or I just got a Friday afternoon card . I haven't heard anything from.the company yet about replacement or compensation for a not so premium nitro +.
I didn't get a cover for the PCIE connector either just the blue covers for the outputs like yours.
I ahve noticed it does need a support on the rear of the card as it does droop a bit near the end. Shame they didn't supply one like they did with the Vega64 I had.
