- 22 Nov 2020
Looks like there is a new driver just for 6800XT & 6900 cards which is the .2 drive.
20.12.1 is the most recent for base 6800.
I also had display port issues, I DDU'd all drivers and started again from fresh which fixed it.
Still rubbish performance in Warzone, great everywhere else. My mates 5700xt out performs it![]()
Thanks I actually upgraded to the new driver 20.12.2 and found Trixx Resolution upscaling working OK.
With the display ports I was actually being OCD and trying to pull them up and there has to be some give otherwise you wouldn't be able to remove the plug! (The plug doesn't move downwards or side-side when prodded)
If you properly seat the Display Port plugs with a clunk/click or whatever then there's no issue.
Wish I didn't have OCD!!!! Life would be so much simpler- I've just wasted 24hrs worrying about it until I concluded the above.
I'm getting 150 FPS at 1440p on Forza on MAX settings, 170 FPS @1440p in Cold War COD without Ray Tracing (about 90-100fps with Ray Tracing on Ultra), haven't tried warzone yet- can't think why it would perform worse?
