Underboss
- 20 Oct 2002
- Oxfordshire / Bucks
You need to check if the game has 'supports Quest' as well as 'Supports Rift' in the description. If it does then if you buy it on the desktop app you'll be able to buy it for free for Quest on the phone app.
cool, it says supports Rift, Rift S and Quest
so i can get it quest for free then
Why is it cheaper on the desktop app as opposed to the phone app
no point buying it on the phone app then is there ?
