Caporegime
- 21 Jun 2006
Yes of course, quick photo below.
This one has an Amazon Fire 10 inside. Made a wall mount that sits flush with the wall and has 5mm magnets in 8 or so places that clip the front frame to it really neatly (means I can easily pull out the tablet if I needed to). Reckon the cost of filament / printing was around £2-3 vs your Vidabox mount.....
Happy to print one for you if you were doing it again...! Although for £100 a pop you could get yourself a decent 3d printer for a few of those!
I've kept the sensor on the right uncovered as I use that to display a screensaver of family photos by default and then when it detects someone moving in front of it, it flips to wall panel mode.
Okay I'm sold on home assistant but not the energy meter.
There is literally nothing I need to know how much power it uses when I think about it. I turn everything off anyway that I don't need on.
However I am sorely tempted now to get smart trvs.
I take it a wide range are compatible with home assistant?
Also the tablet you have wall mounted is it running an application or are you simply using a web browser and pointing it to home assistants IP?
How does it get power? Have you installed a usb socket behind the wall mount and use a short lead?
