Did the new update improve performance in VR at all?
I think Air hauler 2 may be the closest, has a passenger option, but not tried it yetI used to play FSX with a mod called PSPassengers - it allowed you to pick up and drop off passengers and handle seatbelt signs and meal service etc. Has a mod been released for this purpose for the new FS?
Replica Garmin GMC 710 from Aviatek in Spain, I have a full G1000 setup on order-should be here in a couple of weeks.That autopilot panel's nice, where's that from?
Having some spanners & hex/Allen keys to fix the plane is going a bit to far![]()
Folks, can I ask... I can see there are two graphics settings now, for VR and for standard.
So if I am running the game in VR, I can still see the desktop projecting what I am seeing in VR.
Is this taking away from performance? Should I set the non-VR graphics settings down?
Those with Quest 2, are you using the 1.7x render resolution? Its very slow in VR i have to say (which I am sure is the same for many).
https://aviatek.com/collections/all/products/av-gmc710
It uses OpenXR regardless, what you want to do is tell your PC which platform's OpenXR runtime is your preferred one... currently it is probably steam's.
I don't use Oculus but this should help How to install OpenXR – Microsoft Flight Simulator Support (zendesk.com)
Both Steam and WMR have a one click option in their respective apps to set as the preferred runtime but for Oculus currently it looks like you just need to do that little registry edit (and make sure you are on the public beta).
Just recently started playing again after a month or two off. I thought I'd noticed these pyramid looking things as I was flying!!!! Have they said the reason behind this bug?Took a meander around southern New Zealand this morning. Only saw one pyramid and it "felt" a little smoother.
 )So much better than the Xbox controller!
Only changed a couple from the default mapping. Added the external view camera to one of the buttons and changed one of the view settings. All else seem ok so far. Although I did wonder why my engine kept cutting out - realised I had the mixture dial/axis turned right down![]()
