DOCSIS regardless of version wont be able to compete with fiber direct to the house. fiber optic cables are capable of 10gig up and down so in the long run virgin will be at a disadvantage.
Between RFoG and 3.1 bringing the capability of both faster than gigabit and symmetrical speeds, I wouldn’t worry too much. Also Virgin has fibre to the pit in many areas along with duct to the property edge, change is a lot less expensive for them if/when it’s eventually worth doing.
that virgin cable from what i can see is just a single or possibly dual copper wire job, what frequency are they running to get 10gbit from it? even cat6a gonna struggle over 10gbit if length is high.
I'm not sure you'll get that. Maybe £34 and some credit.
Well they've already called back begging, but I said unless they can do 350Mbps for less than £30 per month I'll go with someone else.
Hi, I just phoned up to leave due to price increases etc. About 8pm . Got through to a Uk callcentre, lovely lady. Pushed her a bit, went to £30 per month, then went to £27.50/month when I told her that I could get Sky FTTP now in my area. This was for an 18month contract, and protected against any price increases. This is for M350, with no phone line or TV etc etc
That is good to know thanks, will keep that in mind when I talk to them again. How long had you been with them?
Just checked - my install was Dec 2018
Then why is upload so limited on virgin? Even docsis 3 should be 5 times higher than what virgin offer now but from what the engineer told me at time of install is that the network virgin have setup will never get upload matching download.
Coaxial cable was used in the first (1858) and following transatlantic cable installations, but its theory wasn't described until 1880 by English physicist, engineer, and mathematician Oliver Heaviside, who patented the design in that year (British patent No. 1,407)
