NR200 Owner's Thread
For those running Ryzen 5000 CPUs...I just did the Agesa 1.19.0 update to my Mobo and did the undervolt per trusty OptimumTech and my 5900x runs an avg 5°c cooler (65ish vs 70ish) now when playing CyperPunk 2077. Runs even quieter now that temps are lower. In addition my max boost clock speeds went up from 4.7 to 4.9ghz! Stoked!
Thats with a Cryorig H7 Quad Lumi (intake) with a single Noctua NF-a12x25 on the cooler, (2) NF-A12x25 on top as exhaust and my EVGA 3080 FTW3.
Has there been any recent update on when stock will be hitting the UK? looking about online I can find a couple of places in Germany that have stock in. So was hoping this may be a sign of stock spreading through Europe.
I'm also curious as to when the next batch is coming in. I don't want to order from outside the UK because of the border issue that seems to have delayed some orders for other people.
I ended up buying this case on the MM recently without thinking it through, mainly because it seemed so popular in this thread.
It cost me more than I'd planned due to needing to swap to a smaller motherboard and cooler but I'm pleased with how it turned out in the end even if I did have to attach the 165mm ATX PSU in with tie-wraps.
Glad you got it all built in the end, sorry if I made you spend more money :)
I'd had one on preorder for quite a while but it kept getting pushed back, waiting for the ssupd meshlicious to hit the shelves now
Decided I couldn’t wait for the A12x25 chromax any longer, just ordered 2 P12 PWM’s for up top. The noise was driving me insane, horrible grinding, vibration noises from the top stock fans which seems to get worse after a hour or so I’m guessing once they’ve heated up.
It's somewhat getting there... got a H100i on its way to cram into here at which point I'll probably put two fans up the top too... not sure just yet :D
Guessing they kick in at load?
For me it was this weird humming/reverberation/drone at a certain RPM. closest thing I could think of would be you know when you're driving and you have the windows down a certain way and you get that annoying resonant wind buffeting sound....kinda whomp whomp whomp sounding.
Sorry for my garbage vocabulary but needless to say the CM fans I received were not happy to be hanging and made that awful sound at 1k rpm and higher. I ran them vertically on my cpu cooler while I waited for my noctua to come in and they did NOT make that weird sound. So it has something to do with the bearing design and not liking to be hanging from the top in exhaust orientation. When I put then in intake orientation or vertical orientation they did not make the terrible sound.
Maybe me and some others got a bad batch since some people are happy with theirs...or maybe they arent as sensitive or bothered by the fans. Could be both.
