- 20 Jun 2016
geez...............
People are really fixated about memory size.
You can't put as much as you want on them, depends on the bus of each card and probably on the type of memory. So for the 3060 it was either 12 Gb or 6Gb. For 3080 10 or 20 Gb etc.
geez...............
People are really fixated about memory size.![]()
Because a **60 series card having more vram than a **80 series card makes so much sense? I've a feeling nvidia could have launched a 3050ti with 2 gigs of ram and you would be happy about it.
Can someone explain what the hell the point is of having 12gb of VRAM on an GFX card less powerful than a 3060Ti?
This is possibly the most nonsensical GPU generation I've seen.So no 20 GB RTX 3080 Ti / Super, but a 16 GB RTX 3080 for laptops. Oh well.
If it runs everything at 4k quicker than competition ....
Who cares?
good to know. that will explain why currys are advertising it again this evening. ThanksCod Cold War code redemption period has been extended to March 11th, as long as you purchase a 3080 or 3090 by February 11th
I got one with my FE, sold it for £30 and Geforce Now for £5. Every little helps.good to know. that will explain why currys are advertising it again this evening. Thanks
does it come with all 3080s? even the FE? if so those lucky few who get an FE at rrp get a nice deal!
Noice. So Ampere was never compatible.And Re-Size bar support announced
Unfortunately, a driver update is not enough.
To get re-size bar working, you will need to flash your RTX3000 GPU with a new bios - the new BIOS will be released in March.
Once flashed, update to latest driver and latest motherboard BIOS and Re-Size bar will work
Nvidia re-size bar works on Intel 10th gen, Intel 11th gen CPU and AMD Zen 3, Zen 2 CPU and its works on pcie3 and pcie 4 motherboard
Nvidia would have been happy to stick 6GB on it. But it would have been slated when AMD brought something out with 12/8 GB at that price point.Well that was a anti-climax of nothingness.
As I totally don't get it.![]()
By then Ampere may have reached half it life cycle. Lol.I pretty much guarantee there will be a 3080Ti, as well as a 20GB 3080 but stock issues seem to be holding things back.
