RGB Strips
17 Feb 2009
Just looking at some RGB strips. I understand my mobo requires 12v connectors, and I have two RGB headers on the mobo.
However looking at the pictures, they have two connectors ? IS this to connect one side to the mobo, and the other side into a seperate RGB strip ?
Just so it can be extended.
Nice one thanks.
Now just to think where to put some RGB strips lol.
My 3 fans have red RGB. The underside of the case has RGB and the mobo has a tiny bit too. Don't think there's much space for any more tbh...
There's an RGB strip perhaps 12" long inside the case, however the cable isn't connected to the mobo and it looks like a molex connection. I thought most RGB strips connect to the JRGB ports on the mobo.
It's definitely not connected to the Mobo as I installed a B450 recently and nothing is connected to the JRGB ports. any idea ?
My front two intakes are also molex.
Here you can see the connections.... if i could somehow connect that 12v strip to my mobo i'd be able to control the colours ( i think ) ....
