Show Off Your Call Of Duty Warzone Graphics Performance
Caporegime
12 Jul 2007
United Kingdom
How does Warzone perform for you? I see mixed reports out in the wild with some users reporting stuttering or low performance and others saying it runs great.
Feel free to share your performance reports or preferably video reports good or bad and show off your skills (if you have them - which i don't :p).
I find this game runs very well at my monitors native resolution, 5120x1440, or 1440P - which i often use for recording footage.
Try to follow the following thread format if you want to contribute any report.
Game Mode: Mini Royale
Resolution: 1440P
Image Quality: Maximum, but with RT/Blur/DepthofField/Grain Off
CPU: 5950X
GPU: 6900 XT
Video:
Beastly FPS there - how does the 6800XT compare ?
Can you do a similar vid in 4K as my 1440p results are way too shameful to compare :p
10%-12% worse is my estimate based on the tests i ran when i had a 6800 XT.
I would run 4K but my Ultra Wide does not support it unfortunately.
I am actively trying to procure a 4K display for 'work purposes' though. :p
Why are we having games in here? First with Cyberpunk, and now with Warzone. Do we need a dedicated benchmarking subforum or something?
And a game no respectable reviewer would use due to obvious reasons as it's too variable for comparison. Find least demanding area of map, call it a win and best card. :rolleyes:
i dont know how to benchmark this game OP?
this game has no benchmark, there is no way to do an apples to apples comparison
It’s not supposed to be a benchmark. Just play some Warzone, capture some footage and share you settings. It’s a very popular game so graphics performance comparisons are interesting.
3070fe/3600
Nvidia filters on
3440 x 1440p
Full screen borderless as I have 2 monitors
I pull 110-120fps on high settings. Everything default settings I get around 140fps but the game just looks terrible and bland.
Rebirth I get around 140-150fps with above settings.
looking forward to DLSS integration though.
Testing or discussing GPU performance in games doesn't belong in the Graphics Cards subforums?
Apparently not. Everything boils down to "wins" for some people.
Since warzone is popular and people are upgrading(or trying to) different comparisons in multiplayer situations and different resolutions (not normally benchmarked in reviews)might be useful for someone to see if it's enough for them (the difference between 3060ti and 3070 etc)or to see if they also need a full system upgrade to drive their new gpu.
But no....not in the graphics card subsection. It's a shame that is the case really. And that you are better off watching random videos on youtube than coming to an enthusiast forum to find out how multiplayer games run on different setups.
Unless it's a Digital foundry or hardware unboxed video that can be used to sling mud it's not welcome.
Lately, there has probably been more talk on consoles performance than anything else(excluding the "wheres my GPU" threads).
Resolution: 1440P
CPU: 5950X
GPU: 6900 XT
Video:
I've always found this runs smooth as silk for me... these are not my normal setting as i normally play at 4k but for the purpose of this benchmark copied your exact settings although just realised its a quads game on resurgence but i doubt that will change thing much as same map :D
Game Mode : Resurgence Quads
Resolution : 1440p
CPU: i9-10900K
GPU: RTX3090 Strix Oc
I'm liking looking at everyones videos here.
I'm in the process of trying to order a new graphics card so this gives me a good idea of what each card is doing. in Warzone. Its the main game I'm playing. It appears the 3090 has a good amount of frames higher than the 6900XT.
I'm currently using a vega 56 at 1440p Normal settings and usually fluctuate somewhere in the region of 85-125fps.
Anyone gaming on Warzone at 1440P with a 3080?
