I have been thinking about doing a custom lop for a while and started to get parts together to coincide with the new Nvidia GPU release which would be an ideal time to do this.
I have a Hardware Labs GTS360, EK Momentum monoblock, EK Quantum Kinetic combo unit and a EK GPU waterblock for the 3080FE, the missing ingredient so far is the actual 3080FE lol.
Before the 3080FE was announced I thought that it would be more efficient than previous models so I thought the 360GTS would be fine but looking at the temps they are producing then I`m not so sure now.
While I am playing the Discord roulette trying to get the 3080FE it`s giving me time to plan my pipe routing with two options.
Option 1 is to stick with the 360GTS with 3 x fans at the top of the case.
Option 2 is to add a 240 rad at the front of the case for extra cooling although this will bring warm air into the case unless I switch the case fans around so the rear is intake and the three front fans are exhaust.
I will probably be undervolting the 3080 as this seems to be common practice and people are getting good results and more stability as well as keeping temps down.
