Tester
20 Oct 2010
wehvC6G[\img]]
wehvC6G[\img]
wehvC6G[img]
wehvC6G
https://imgur.com/a/wehvC6G
Thanks for that, I tried surrounding it with (img) (/img) with square brackets and it didn't work how did you get it to work?
Using chrome, I right clicked on the image and selected inspect and then looked for the link in the text that contained the image format - jpeg and copied that into the image toolbar popup and boom.
Brill, as you can see above managed to get it to work, thanks I'll be able to post some more soon now
