I seem to be getting a lot of random BSOD's , Crashes to Desktop, and just straight up random restarts
I downloaded whocrashed , which took the dump files and gave me this below....
Running this spec:
AMD Ryzen 3600
MSI Mag X570 Tomahawk
32gb Corsair Vengeance
MSI 2070 Super Gaming X Trio 8gb
Phanteks AMP 650w PSU
I initially suspected drivers, So have updated : Motherboard Bios , GPU Drivers, and WiFi drivers.
The crashes occur across both World of Warcraft and GTA V , Also get the odd crash from Youtube but much less frequent.
I've also run the system with everything except SSD's installed as noticed i'd get a crash on a HDD spooling up from idle (could hear it) , but still got crashes then.
I removed the 2070 thinking maybe that was the cause, but even with an Asus 1060 3gb , I still got a crash (albeit took much longer).
Memtest and SFC also came back clear.
Anyone able to help with what do look at next? Could it be a bad Mobo/CPU? or Even PSU ?
Running this spec:
AMD Ryzen 3600
Code:
System Information (local)
Computer name: DESKTOP-MAINPC
Windows version: Windows 10, 10.0, version 2009, build: 19042
Windows dir: C:\Windows
Hardware: MS-7C84, Micro-Star International Co., Ltd., MAG X570 TOMAHAWK WIFI (MS-7C84)
CPU: AuthenticAMD AMD Ryzen 5 3600 6-Core Processor 8664, level: 23
12 logical processors, active mask: 4095
RAM: 34281984000 bytes (31.9GB)
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Mon 18/01/2021 20:26:35 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\011821-18250-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F5780)
Bugcheck code: 0x139 (0x3, 0xFFFFF50240829060, 0xFFFFF50240828FB8, 0x0)
Error: KERNEL_SECURITY_CHECK_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: The kernel has detected the corruption of a critical data structure.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!setjmpex+0x8299)
On Mon 18/01/2021 10:34:36 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\011821-19109-01.dmp
Bugcheck code: 0x162 (0xFFFFD4831D58B080, 0xFFFF950040607908, 0x1, 0x0)
Error: KERNEL_AUTO_BOOST_INVALID_LOCK_RELEASE
Bug check description: This indicates that a lock tracked by AutoBoost was released by a thread that did not own the lock.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
On Mon 11/01/2021 20:17:31 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\011121-17906-01.dmp
This was probably caused by the following module: win32kfull.sys (win32kfull+0x9F164)
Bugcheck code: 0x50 (0xFFFF8D0A1251ED70, 0x11, 0xFFFF8D0A1251ED70, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\win32kfull.sys
description: Full/Desktop Win32k Kernel Driver
Bug check description: This indicates that invalid system memory has been referenced.
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Wed 06/01/2021 17:57:50 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010621-18984-01.dmp
Bugcheck code: 0xF7 (0xFFF0516DEE3E870F, 0xF067E2BE85BA, 0xFFFF0F981D417A45, 0x0)
Error: DRIVER_OVERRAN_STACK_BUFFER
Bug check description: This indicates that a driver has overrun a stack-based buffer.
On Wed 06/01/2021 12:37:27 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\010621-19203-01.dmp
Bugcheck code: 0xFC (0xFFFFAC858354F7DC, 0x8A0000017938F963, 0xFFFFAC858354F630, 0x0)
Error: ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
Bug check description: This indicates that an attempt was made to execute non-executable memory.
This may be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules. Memory corruption can also occur because of overheating (thermal issue). There is a possibility this problem was caused by a virus or other malware.
