Probably better off asking that in the 6800 XT owners thread?
that's a very good point. I read the thread info incorrectly.
Jesus, that side by side comparison looks ridiculous Lol. Small GPU Humiliation right there.![]()
It hath arrived...
The 6800XT MBA card is looking a little diddy next to it
get your siggy updated ladThanks @Kaapstad it's a Limited Edition![]()
much betterSir yes Sir!![]()
Might be interested in the 6800 if that's getting shifted![]()
No trading outside MM obviously, but I think a friend wants it.
It hath arrived...
Sounds strange. I just set mine to sleep (don't normally have it go to sleep), and it awoke from sleep straight away, no problems.One thing that annoys me is the monitor won't wake, from being asleep. Despite trying with the mouse + keyboard.
The computer knows I am interacting with it, I hear audio, but the monitor doesn't get a signal from the GPU, I never had this issue with my GTX 1070.
Tried that but got the same score. Also tried lowering to 2012 in Firestrike extreme but got a lower graphics score that when set to 2150. The Jury is still out I guess as to whether my card is happy with the memory maxed out or is just pretending too!You are most likely losing performance from your memory overclock. Try dialling it back to 2012Mhz set in Radeon Software.
I’ll upload them to my one drive tomorrow mate, that’s some weird ISP you have. If you don’t use my original profiles the voltage might be wrong.Hard to tell. You’d need to display the voltage on your OSD. It’s not available yet in Afterburner if that’s what you are using. HWinfo64 can show you the voltage via OSD.
Sure, try this link.
