- 30 Mar 2019
Hi all just a quick question, I'm finding it very difficult to mix and match copper sizes most standard copper pipe is 15mm or 22mm which is way to big. So im looking at 1/2" OD soft copper coiled pipe and using 12mm fittings.
Am I right in thinking that the 12.7mm OD pipe will work with the 12mm fittings? Has anyone used any fittings and can confirm this is okay ?
Kind regards
Kind regards
