Are they really that bad?
I need to make some miniatures (3mmx7mmx7mm HxWxD will be the smallest) and I don't think my FDM printer can get the resolution I need. I only want some smooth blobs, no intricate shapes or detail.
I was looking at the Creality LD002R, I know the brand and reviews appear decent.
) but you can get water-washable resins, which allow you to use tap water in the wash/cure tanks, but you still can't just pour the resultant water from those tanks down the drain, could probably let it evaporate though.
