Man of Honour
- 23 Mar 2011
- West Side
A fresh install is always worth a try, opera browser is a good alternative to use.
Memory is it set correct in the bios have you checked this with memtest.Ordered another PSU which is due tomorrow, EVGA G3 850W. See if the issue persists with that, can't really go 7-14 days without a PC! At least I can rule out the PSU.
Download memtest and run it see if theres any errors.Hi mate, using memory in sig, I have just got it set to XMP profile, I didn't touch anything else, any suggestions?
You could also try running at default and test.
Lets us know how you get on.Cheers pal will give that go!
Will do mate! New PSU is due first thing so that will rule that out. Got some more thermal paste due next week although can't see that being an issue as my Corsair AIO is a few months old and temps look okay! I've yet to have one restart in a game, which makes zero sense, why would it reboot on web browsers but not in games under load? all drivers are current even the bios for the 3080. run 3D mark constantly and valley benchmark not one reboot or crash.![]()
No restart in games doesn't sound like a hardware issue , i would do a fresh windows install.
I would do 2 passes but others will say more it does take some time.Thanks, just about to run memtest, never used it before fingers crossed, any idea how long to let it run or for what amount of time?
Interesting issue but an annoying one when u can't find the culprit!
I would do a windows reinstall. Sounds like driver/ codec issue if memory tests are fine.
Did some digging a few nights ago and people claiming to have had similar issues with Corsair iCue software causing random BSODs / Rebooting and shut downs. Low and behold (touch wood!) since I removed it a few days ago I've not had a single reboot. Hopefully that was the culprit!
