Will my 3600x bottleneck?
30 Sep 2008
surrey
What do you guys and girls reckon. I have just brought a Sapphire nitro+ oc RX 6800 GPU. I use a 1440 144hz monitor and am wondering if i need to upgrade my CPU . My mother board is an Taichi x570 so no issues there with moving to zen3 if required.
18 Oct 2002
Manchester
IMO no, the 3600x won’t be a bottleneck, it’ll be fine. There will be increases on Zen 3 in some instances, and if you want to upgrade I guess it wouldn’t be the worst thing, especially considering you’ll be able to sell the 3600x easily second hand.
hardware unboxed did a video showing what you are likely to see as an increase, if any, going up from a 3600
Permabanned
10 May 2013
Under the Firmanment
I upgraded from the 3600 to a 5800X. I couldn't get the 5600X. The difference in Arma 3 multiplayer is amazing. So much faster. Star Citizen is kinda playable, shame it is a bore fest. CSGO my frames never drop below 380. I upgraded because I am replacing my laptop with a mini ITX build using the 3600. I haven't seen much difference in the console ports (AAA titles). A bit faster but not night and day like Arma 3.
6 Jan 2012
You know the old adage, keep all the bits same gen, then you know its all working at its best. True, but not cheap ;)
3 Mar 2015
Wokingham
Doesn't it depend on your choice of games?
I have a 3600 abd it doesn't bottleneck the games my kids play at 4K 144 fps.
