 - 27 Sep 2020
has anyone receieved an email about the 5950x is being shipped?
Idle is around 40-42C with max of 71-72C on sustained heavy loads (gaming, stress testing or benching), ambient is 22-24C, water temp in the loop is 38C at idle and maxes out at 52 after sustained (looong) stressing again in gaming, rendering or benching/stressing, while GPU maxes at 56C and idles at 35C. I do get occasional momentary spikes of 80-81C on the cpu but that’s only for second or so. Max clocks I’ve seen with the current setting is 4.9-5Ghz on a single core (but doesn’t stay there long) and sustained 4.7Ghz on benching all cores.What temps are you seeing with PBO on and using the performance plan?
I'm hitting 85 to 90c in R23 on a full 10 minute run, ~70c in games.
Its a 2 year old 120mm AIO, it ran the 3600 in the mid 60's while hardly even ramping up the fan, silence was golden, not so with the 5800X, i am surprised how much hotter they run but its an 8 core 16 thread CPU, time to get a proper cooler.....
Anyone running the Arctic Liquid Freezer II 240 or 280? I hear they are pretty good.
I've not issues with my Noctua D15s; but if you want an AIO better look up a few reviews. I dropped my Corsair H110i for the Noctua it was cooler and quieter.
I prefer AIO's, much cleaner and the 280mm Arctic Liquid Freezer II looks plenty capable in reviews.![]()
Aren't those the ones with the internal gunk build-up?
Yeah they are crap.![]()
It’s normal try not to worry. I get a similar spike to 80c for less than a second when I play Far Cry 5 or even load up 3DMark sometimes. Generally though when playing most games temps are in the high 50s -low 70s.Yeah that's what really bugs me about gaming. COD:Black Ops seems to be the worst, it will spike in to the low 80's for a few seconds. It's a hot CPU that's for sure, my 3900X would barely ever see in to the 70's after hours of playing, yet this can almost spike in to 70 for a second just opening Chrome![]()
If i ever manage to get hold of a 5900X i'm using my NH-D15, don't think i'll ever buy an aio as i don't trust them.
Just finished setting up my new case with the Crosshair VIII Dark Hero (3003) and the 5950X, stock settings apart from enabling XMP. My Cinebench R23 scores look to be about right seeing what's being posted here.
Single; 1644
Multi; 25598
**edit** removed screenshot, thought I was posting in benchmark thread.
