- 24 Sep 2015
The UDM is a solid choice, sorry if my post implied otherwise.
Mainly the fact it ideally needs a dedicated PC, or at best virtualised with a network card passed through to it for best performance. For an enterprise environment where you don't have the budget for a "big-name" device, it's ideal - ours has been rock solid, but for a smaller network it's complete overkill.RE: pfSense. How interesting. Why wouldn't you want it at home ?
They're small, use a tiny amount of power, and built for enterprise rollouts so will happily run 24/7 without any fuss. Some of the models can be had dirt cheap as well - plenty of different models reviewed at the below siteRE: The hardware. What makes those mini-PCs the better option?
For the record I appreciate the 4790k is excessive, but the parts are literally just gathering dust, and for £80ish would give me a complete build. Wouldn't it be more than capable of doing everything I need and more?
For the router I've decided on the Unifi Dream Machine, it does what I want, I'm familiar with the software, and it's a new product that will continue to evolve and improve. I can also expand by switching out my dumb switches if I want. Plus youve set my mind at rest about some of the horror stories.
I'm liking the look of the DM more and more, I originally wanted the ER4 but this looks a better bet.
Want it to handle full FTTP easily, which oddly majority of routers can't do.
Amplifi Alien seems interesting as well but not looked at that yet.
The Amplifi is decent, but it's very much a consumer orientated router. It's designed to be user friendly and as such, is missing a lot of control options. The UDM is more of a prosumer router, it's on the fence. You're lacking the control you may need for an office or other larger installation, but it has more than enough features for small business or home use.
Thanks.Amplifi isn't the same development group as Unifi or EdgeMax and it's very much the stepchild which has been banished out of the main UI forums like an embarrassment. Everything else is all in one place - Protect, Talk, Unifi, EdgeMax, AirMax, AirFibre, GigaBeam, UISP and UFibre are all on the UI forums. But Amplifi is off by itself in a dark, forgotten alley. If you go with the UDM or UDM Pro the world of Unifi is open to you but for Amplifi users they're stuck combing eBay for remainder stock or used Amplifi repeaters once that model stock is sold through. It's a dead duck product.
How does the UDM attack up speed wise with the ER4, I'm used to comparing the packets per second but can't find it for the DM.
Also sooner of the reviews of the dream machine say it's not ready and it's like a beta product.
Straight away I'd want guest network, with zero access to the network storage for instance.
Secondary network for my smart network stuff to again limit what they can access.
Custom DNS so I can use the Pi-hole on my NAS.
What would packet inspection enable me? Not sure what is be losing with DPI.Guest network is a Unifi controller feature. It's literally just a tick in a box and it creates the guest network with the name you assign it.
You can create multiple physical networks and VLANs.
You can certainly assign any DNS server you like, but PiHole breaks DPI so your statistics are broken.
Hey @WantoN. Your setup is pretty much the same as mine because I also have a single AP-AC-Lite so I was quite excited to see which direction you'd take when I read the thread.
Did you get the Dream Machine? If so, what are your impressions of it? I was interested in the pfSense SG-2100/3100 routers but they're perhaps a little complicated and overkill for me. I absolutely love my AP-AC-Lite so the Dream Machine seems like a no-brainer on paper, but the software bugs do worry me and it's disappointing that they didn't include PoE and Wi-Fi 6.
Hi mate,
I've not acted yet. Money is very, very tight so I need to be careful.
I'm considering Mikrotik equipment. Very competitively priced, and very powerful. Less than a third the price and does most of what I want. It's down to their HeX S, hAP ac³ or the UDM.
I decided to build out my mini server first as it's going to cost me very little and I can try pfSense (and alternatives) on it.
I'll update if and when I go ahead, and with what.
I looked at the Amplifi but wasn't impressed with the range, and the software is comparably quite limited.
I'm also wondering if Ubiquiti will release a WiFi6 successor.
That HeX S actually looks perfect, especially since it includes a PoE port so I could ditch the PoE injector for the AP-AC-Lite.
I’ve always heard that RouterOS has a steep learning curve, but my requirements are very simple so it shouldn’t be too difficult to configure a basic WAN+LAN setup.
Opportunity to learn mate
One thing about the Mikrotik is that most of the Poe is passive, so check your specs.
At that price it's hard to argue, especially when we've both got APs already!
The PoE is indeed 24V Passive but luckily the UAP-AC-Lite, UAP-AC-LR and UAP-AC-M can all be powered from 24V Passive PoE, so the plan would work. Sort of. Because it’s on PoE pass-through, so you would power the HeX off the PoE injector and then take the feed to the UAP-AC-Lite from the pass-through port on the HeX.
Damn. Was hoping to get rid of one plug under the TV cabinet![]()
