RTX 3090 Boost Clock
3090FE stock settings
68c - 71c 1830/1860 boost
That's after a couple of hours of cyberpunx 4k ultra rtx or rdr2 4k. Poor airflow case, good fans at low - med speed.
Edited to add - after turning my case fans upto 1000-1200 rpm which is as much noise as I'm prepared to put up with and undervolting the card it is now sitting at 1950 boost at 69 - 70c. Can't hear the gpu over the case fans. Which is nice.
Good question I can honestly say I don't know, just quoting what comes up on Afterburner overlay?
Mine (albeit a lowly 3070FE) always boosts up and down by 15mhz. I’ve seen others quoting undervolts at speeds that aren’t divisible by 15 and was always a little confused by this!
Thanks all good to know, wee silicone lottery i think!
Mine is perfectly stable after a few hours on CyberPunk or WD Legions, sits at 48oC and 2055Mhz....It is under water though...
It's the ram temps that are a shocker. My 3090FE rarely goes above 70 degrees on stock (Boosts to around 1750, but my case cooling isn't amazing) but the ram gets up to 102 degrees. :eek:
Gigabyte Vision OC undervolted to 0.875mV, solid 1935mhz boost with good airflow. Floats between 60-70C, more towards 70C in cyberpunk with ultra everything, much lower in other games, but never over 70.
I'm running a Lian-Li O11d-XL with 2x360mm rads 60mm thick. 5900x and 3090 in a single loop:
Can't seem to post pics but here's the URL to it
I've just flashed my TUF to the Gigabyte Gaming BIOS for the 400w power draw. Cyberpunk crashes with the same overclocks so I'm troubleshooting that atm. Had to knock the core down a bit, now boosting at 2005Mhz at 40c but it's only using about 80% GPU (FPS locked to 60)
