- 23 Nov 2005
- Kingdom Of Fife
Hi All, what are your card temps and boost clocks like when gaming?
I thought they boosted in 15mhz increments?3090FE, undervolt to .0850mV with 1925MHz set clocks. Starts at 1890MHz coming from pause menus etc then pops and stays at 1925MHz
Mine (albeit a lowly 3070FE) always boosts up and down by 15mhz. I’ve seen others quoting undervolts at speeds that aren’t divisible by 15 and was always a little confused by this!Good question I can honestly say I don't know, just quoting what comes up on Afterburner overlay?
It's the ram temps that are a shocker. My 3090FE rarely goes above 70 degrees on stock (Boosts to around 1750, but my case cooling isn't amazing) but the ram gets up to 102 degrees.![]()
Asus TUF 3090
45c under full load (custom water)
2040Mhz (100Mhz core overclock)
