VESA Mounts?
DHR
DHR
30 Apr 2003
Anyone mounted an ultrawide with a vesa mount recently?
Thinking of getting one that'll do height adjustment too, can only see them going up to 27" monitors so far but I'm doing a 38"
2 Nov 2003
I am using a AmazonBasics single monitor mount with my Dell Alienware AW3418DW so you will be fine with one off those as long as the monitor does not weigh more than 11KG which even the 38" version does not come close to.
I think my Dell is around 8KG without the stand attached.
DHR
DHR
OP
30 Apr 2003
I'm after a wall mounted one really, sorry should have been clearer.
I've got one that'll do for now, I was just after that height adjustment though.
2 Nov 2003
Google, Huanuo 24"-35" led lcd monitor wall mount that may be more what your looking for then.
DHR
DHR
OP
30 Apr 2003
Cheers that's more like it. When I originally did the mount for a 32" with one of these it wasn't hidden so may as well have been attached to the desk, lost the floating effect.
Think I'll retry my old one first and see how the heigh works out with that, and if not pick up one of the Huannuo ones.
