**THE NVIDIA DRIVERS THREAD**
15 Jul 2008
I have made the switch from AMD to Nvidia when I picked up a 3080 FE a couple of months bad and I'm surprised to see drivers as much as an issue as with AMD. I do find it weird how much stick AMD got for it while Nvidia get very little.
I'm just sticking with the drivers that work for me and the games I'm playing currently which appear to be 460.89 (all newer ones caused issues) and won't bother updating them until I start playing a new game that doesn't work with them. I did exactly the same with AMD drivers and just used 20.4.2 AMD drivers for 4 months without a single issue. Newer drivers just seem to break stuff that used to be working in the effort to fix other issues and that seems the case for both AMD and Nvidia
15 Jul 2008
There are just so many combinations of OS versions/updates, Motherboards, RAM, Processors, Other Drivers (chipset/audio etc) so many variables that can cause issues.
Must be a nightmare creating/testing these drivers as they would only be able test certain combinations of hardware/software.
6 May 2009
Best way. 445.87 I used with my 2080Ti all the time. Unfortunately that driver is not supported on 3080 so 460.89 it is for me. It seems the most stable at the moment
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Yeah, it is weird isn't it? Don't criticize the firm man.
Caporegime
8 Sep 2006
On Ocuk
Tried these, 2 things
1 - DCH drivers
2 - Got an Out Of Range Error on my monitor playing COD - loaded the game - screen went black - had to hard restart. Uninstalled I'm afraid. Titan Pascal
Worked fine on the 980 GTX, but don't work on the RTX so I've had to uninstall and try again :(
Caporegime
8 Jul 2003
In a house
'Nvidias drivers don't have any problems, they just work'
:p
31 Dec 2007
The TARDIS, Wakefield, UK
Only the officials I'm afraid
https://www.guru3d.com/files-details/geforce-460-89-whql-driver-download.html
I can't use the clean ones as it breaks Geforce Experience Game Sharpening :)
I can't find the 460.89 clean ones on guru, only 460.79, anyone fancy have a copy and fancy wetransfering them to my trust? Pretty please??
Download this and do your own. You can even stick in Geforce Experience.
https://www.techpowerup.com/download/techpowerup-nvcleanstall/
