I think this is normal from what I've read. The article does say don't panic when you see high temps for the memory and it won't start thermal throttling till 110C so guess this is as expected for a FE.How come so high?
I just installed thermal pads on my backplate (none previously) and new ones on the cooler (13w/mk all round), and it reduced my mem temps from 110 to 82! Amazing that gigabyte were so cheap on a high end part. Fans no longer hot 100% under any condition I've found so far
Open afterburner, lower mhz 350, press ctrl f, move 1 point to the mv/mhz you want, click apply and it does the whole curve
Please induct me dear sir!
Hello, did you turn Gsync off? I was getting 17100s too first, but then after disabling Gsync it rose to 17300s. Still lower than expected at stock. Did you come across any fix? I made a post about this a few minutes back. I have a 5600x paired with the 3080fe.A bit, sure. Running stock with 115% power limit results in 17433 timespy graphics score. Still below what others are getting at stock without increasing power limit. Its an odd card or my mobo+cpu is affecting scores.
Edit: my PWR_SRC voltage is around 12.7v during load and sometimes reaches 13v. Anybody know what PWR-SRC is and which component in the PC affects it? Cant be PSU as I replaced mine to be on the safe side recently as it was 9 years old (went from 850W to 850W so was purelyfpr safety because it was out of warranty, which was 7 years).
Hmm it’s certainly not margin of error in my case as I’ve run it several times. I’ve not crossed 17345. And my overall score is low too at 14873 when the average is 15,500. Only explanation is that the average is high because of oc numbers in timespy.Got the same set up, 5600x with 3080fe.
I dont think there is any fix. It appears 17k score is somewhat common. Oddly enough turning gsync on or off does not change anything.
Looking at 3dmark statistics, average score for 5600x + 3080 is about 17.5k and considering this is all 3080 (fe and aib) it could be argued that 17k score is within margin of error. I mean its just 3% below.
The issue is definitely not PSU as I swapped that out for a new one. Does not appear to be a software issue either. Might be something to do with a mobo - x570 pro carbon in my case.
But 17.3k score that you have is within normal average score, so I dont think you need to fix anything.
Undervolt that thing. I got mine at 1845 @ 818mv with +700 on memory. RT stable, much quieter and gets around 17.4k timespy score. Good enough for me.
Yes, this is one possible explanation given the crashes that many aibs were facing during launch. Do you own an fe? And also what cpu?I've noticed my score has got steadily lower since launch where I got 17500 at stock and 18300 overclocked to now 16900 and 17400 so maybe nvidia has slowly dialled back performance in the drivers.
This is on the ventus +'5800XYes, this is one possible explanation given the crashes that many aibs were facing during launch. Do you own an fe? And also what cpu?
Weird. Same power limit of 320w as mine. I really don’t know what’s wrong.This is on the ventus +'5800X
