- 18 Feb 2007
- London
Oh I see that's on ATV so will watch that this weekend
What setting does everyone have theirs on? i go between +5/+7
Sub volume -1
bass and treble at 0
loudness on
Sub volume -1
loudness on
maybe I need to reduce my sub!![]()
Started to get the Beam mounted today, but then saw it says it needs toggle bolts. So will have to order some.
Still on the fence for the Arc atm, would like to get the Beam upstairs and then AV amp wired back in
I'm moving house soon and my current AV solution isn't going to work, so I'm going to downgrade my Monitor Audio Gold system to Sonos using an Arc and a sub. I've got two spare Play 1's which I'll use as surrounds. Are there any discount codes, ways to get a deal on these? Or is it a case of having to pay the RRP?
Cheers. I've also worked out I get 15% off an order up to £2500 from Sonos themselves so I may end up using that.Sonos refurb store sometimes have good bargains.
You can also use old S1 hardware to get a discount on new stock. I got 30% off codes for each of my old Play 5 Gen ones. Be worth looking if you can pick up some old kit off eBay purely for the discount codes. One 30% off code can be applied to an Arc/Sub combo, so there's a decent saving to be had.
Are the 30% items guaranteed to work?
I think Sonos have changed the way the 30% thing works as now I believe it's 30% equivalent products.
I could be wrong but that's what it looked like when I checked before I bought the sub
I bought a Sub just before Xmas and had no problems using the 30% off from a Play:5. I can't remember if it worked for the bundles, I believe it did but most were out of stock so could have imagined it.
Ah I thought I read on SevenOaks that they would only do the trade in on something similar.
I'm wrong 99% of the time so why not be wrong here as well
Well there you go then, I was wrong!Sevenoaks do offer a trade in. The discount I'm referring to is direct via Sonos instead.
Had an email through today about an unveiling event on the 9th March, will be interesting to see what they’re going to bring out / renew as I don’t see too many gaps in the current lineup...
