- 28 Dec 2020
What does this option do in MSI AMD Bios? I have three options to choose from Auto, Gen1, Gen2.
I was confused because there was gpu pcie gen option and this one, which I had no idead what it was. But thanks to you now I know.It is for the non GPU PCI-E slots to fix compatibly issues you may/could have with some older devices.
Your GPU x16 slots will be same but say also have Gen 3.
Yes, I have second nvme and pcie slot which both can not be used at the same time and it supports up to gen2 speed. ThanksFor the smaller slots like if you fit a Soundcard etc and it acts up.
