Will my PSU be enough for 3070 ?
9 Feb 2021
Hi,
Recently i bought 3070 and thinking if my psu will be enough for this gpu.
I've seen many opinions some are saying 550W will be enough some 650W and some even 750W so i'm confused
I have KOLINK ENCLAVE - 600W Gold
Is this enough or should i get a more powerful psu
Thanks all
24 Jan 2006
any recommendations for a better one?
aiming for less than 100 if possible
Depends which CPU and if you are getting a high tier 3070.
Some CPU such as 3600, 3700x are only 65w. If you have a clocked I9 then that could be 200w.
Stock FE 3070 is power limited at 240w, most of the AIB cards are only 260w.
My 3700x and 3070 with custom loop WC pulls less than 350w from the wall in 3dmark.
OP
9 Feb 2021
I've already talked about it in a slightly different thread and decided to take TX750M which is 750W for 95pounds.
Any other thoughts let me know
